APPLICATIONS
MODEL CABLE
PRIDE ADC110-B / ADC132
VISTO ADC110-B / ADC132
AVELLA ADC110-B / ADC132
RIO ADC110-B / ADC132
SEPHIA ADC110-B / ADC132
SHUMA ADC110-B / ADC132
CARENS ADC110-B / ADC132
SPORTAGE ADC110-B / ADC132
CLARUS ADC110-B / ADC132
OPTIMA/MAGENTIS ADC110-B / ADC132
ELAN ADC110-B / ADC132
POTENTIA ADC110-B / ADC132
ENTERPRISE ADC110-B / ADC132
CARNIVAL/SEDONA ADC110-B / ADC132
RETONA ADC110-B / ADC132
JOICE ADC110-B / ADC132
TOWNER ADC110-B / ADC132
PREGIO ADC110-B / ADC132
FRONTIER ADC110-B / ADC132
PICANTO ADC110-B / ADC132
AMANTI ADC110-B / ADC132
Note: Use ADC132 if there is a 20 pin socket fitted in the
engine bay.
13
GENERAL OPERATION
INTRODUCTION
The Kia Immobiliser system called the SMARTRA manufactured by
Bosch consists of the SMARTRA ECU which has its own CPU which
controls the vehicles immobiliser in conjunction with the engine
management ECU.
There are 3 basic systems used on the range of vehicles :-
SYSTEM 1
BLACK key system—TEXTON Read only key head
Minimum keys required for programming 2.
Maximum keys programmed 5.
SYSTEM 2
BLUE key system—ENCRYPT key system
Maximum keys programmed 4.
SYSTEM 3
GREEN key system—SHINCHANG ENCRYPT
PIN CODE ENTRY
On earlier vehicles the pin code is a 4 digit code, which is standard
and set to 2345.
On later systems the pin code can be either:
a) 6 digit code, and available from the dealer.
b) 5 digit code, which is the last 5 digits of the chassis number.
c) Converted from the chassis number. See Pin Code Converter
in the Special Function section.
13
SPECIAL FUNCTIONS
KEY PROGRAMMING—SYSTEM 1
ECU IDENTIFICATION
FAULT CODES
SPECIAL FUNCTIONS
DIAGNOSTIC MENU
PRESS ENTER KEY
> PROGRAM KEYS
> CLEAR KEYS
> KEYS PROGRAMMED
DIAGNOSTIC MENU
PRESS ENTER KEY
SECURITY CODE
_ _ _ _
SECURITY CODE
2 3 4 5
IS THIS CORRECT
OK = ENTER CLEAR =BACK
From the main DIAGNOSTIC MENU
select the SPECIAL FUNCTIONS.
Select PROGRAM KEYS.
Enter security code.
NOTE : This code is normally 2345
NOTE 2 : If this is incorrect then the
dealer who supplied the vehicle may
have changed it. If this is so, please
contact the dealer.
If key programming is successful, then
procedure complete is displayed.
NOTE : REPEAT PROCEDURE FOR ALL
ADDITIONAL KEYS REQUIRED.
PROCEDURE COMPLETE
13
SPECIAL FUNCTIONS
KEY CLEARING—SYSTEM 1
> PROGRAM KEYS
> CLEAR KEYS
> KEYS PROGRAMMED
DIAGNOSTIC MENU
PRESS ENTER KEY
SECURITY CODE
_ _ _ _
SECURITY CODE
2 3 4 5
IS THIS CORRECT
Select CLEAR KEYS from SPECIAL
FUNCTIONS menu.
contact the dealer.
When all keys are cleared PROCEDURE
COMPLETE will be displayed.
PROCEDURE COMPLETE
13
SPECIAL FUNCTIONS
KEY PROGRAMMING—SYSTEM 2
ECU IDENTIFICATION
FAULT CODES
SPECIAL FUNCTIONS
DIAGNOSTIC MENU
PRESS ENTER KEY
> PROGRAM KEYS
> KEYS PROGRAMMED
> LIMP HOME MODE
DIAGNOSTIC MENU
PRESS ENTER KEY
SECURITY CODE
_ _ _ _ _ _
SECURITY CODE
1 2 3 4 5 6
IS THIS CORRECT
From the main DIAGNOSTIC MENU select
Enter 6 digit security code.
NOTE : The 6 digit code is available
from the vehicle dealer.
Switch IGNITION ON and press the
ENTER key.
SWITCH IGNITION ON
AND THEN PRESS ENTER
13
SPECIAL FUNCTIONS
LIMP HOME MODE—SYSTEM 2
PROGRAM KEYS
INSERT NEXT KEY
& THEN PRESS ENTER
PROGRAM KEYS
PROCEDURE COMPLETE
The key in the ignition will be added to
the system.
To program additional keys press the
ENTER key, or BACK to exit programming.
If ENTER is pressed then additional
keys can be programmed.
Repeat for all additional keys.
If BACK is pressed and all keys have
been programmed the
PROCEDURE COMPLETE is displayed.
Select LIMP HOME MODE.
Insert security code 2345 and this will
enable one start to get the vehicle to a
dealer or workshop if further testing is
required.
ECU IDENTIFICATION
FAULT CODES
SPECIAL FUNCTIONS
DIAGNOSTIC MENU
PRESS ENTER KEY
> PROGRAM KEYS
> CLEAR KEYS
> LIMP HOME MODE
DIAGNOSTIC MENU
PRESS ENTER KEY
13
SPECIAL FUNCTIONS
PIN CODE CONVERTER
EURO
USA
KIA SYSTEMS
DIAGNOSTIC MENU
PRESS ENTER KEY
PINCODE
TYPE 1
TYPE 2
TYPE 3
TYPE 4
PRESS ENTER KEY
PINCODE CONVERTER
SECURITY CODE
1 2 3 4 5 6
IS THIS CORRECT
select the KIA SYSTEMS.
Select PINCODE.
Press the ENTER button
Insert the last 6 digits of the VIN or
CHASSIS number.
Then press ENTER
Please wait for program to convert the
number, this will take 5 minutes.
The 6 digit Pin code will then be displayed
for use on key programming.
NOTE : This will use a token.
VIN TO PINCODE
PLEASE WAIT
PRESS ENTER KEY
VIN TO PINCODE
PIN : 582656
DIAGNOSTIC MENU
13
13
TIPS & HINTS
When programming keys, please note the following:
1. The transponder aerial has a resistance of 21.5 Ohms
2. The immobiliser control unit does not return any information to
the tester about the key programming procedure, therefore it is
possible to input an incorrect security code and continue through
the programming procedure.
3. When programming a key, the horn will sound for 0.2 second to
signify the key programming action.
4. Once the first key has been programmed you should turn the ignition
on with a second key and wait for 10 seconds, the horn
should again sound- if it doesn't, switch on the HRW (Heated
Rear Window Switch) to complete the programming phase.
5. NOTE :-2 keys must be programmed to close the procedure.
6. On Hyundai & Kia vehicles the Clutch must be depressed to start
the vehicle.
7. The cooling fan may run on some vehicles when the TESTER is
connected.
8. Damage to the immobiliser control unit if the incorrect transponder
is used. Crypto transponders are used.
9. A minimum of 2 keys must be programmed to close the system
- Board index Clubs Ατυπα η Τυπικά KIA Club
- Search
- It is currently Sun Jan 11, 2026 18:50
- All times are UTC+02:00
προγραμματισμός immobilizer
Jump to
- ↳ Ανακοινώσεις των Λεσχών
- ↳ Ανακοινώσεις του Forum
- Αγώνες
- ↳ Αγώνες 4Χ4
- ↳ Αλλοι Αγώνες
- Νομικά - Φορολογικά
- Μικρές Αγγελίες
- ↳ Ψάχνω να βρώ
- ↳ Πουλάω - Χαρίζω
- ↳ Προσφορές Επιχειρήσεων
- Φωτό - Gallery
- Πεδίο Δοκιμών
- Clubs Ατυπα η Τυπικά
- ↳ Military
- ↳ Συγκεντρώσεις Εκδηλώσεις
- ↳ Διαχείριση Υλικού
- ↳ Κάγκουρες 4x4 Club
- ↳ Οι Κάγκουρες 4x4 Club
- ↳ Daihatsu Club
- ↳ Terios....
- ↳ Ford fun Club
- ↳ ISUZU Club
- ↳ Jeep Club
- ↳ KIA Club
- ↳ Land Rover Club
- ↳ Mercedes Club
- ↳ Mitsubishi Club
- ↳ Niva Club
- ↳ Nissan Club
- ↳ Suzuki Club
- ↳ Toyota Club
- ↳ SSANGYONG Club
- Τεχνικά Θέματα
- ↳ Service manuals
- ↳ Παρατηρητήριο Τιμών
- Τα Περιοδικά
- ↳ 4ΚΙΝΗΣΗ ΜAG
- ↳ 4X4 Magazine
- ↳ Και άλλα Περιοδικά
- Hall of Fame
