PowerWinch hydraulic series provide pulling power from 10000 LB up to 22000 LB with single line operation. It is ideal for tow trucks, utility, industrial and trailer application. Heavy duty hydraulic motor provide powerful torque and constant line pull speed. 100% steel chassis construction and self-locking hydraulic brake is highly reliable and robust. Winch construction and self-locking hydraulic brake is highly reliable and robust. Winch construction and all components meet European safety standard and CE compliant.
The winch features:
1) Robust hydraulic motor with load control valve delivers high efficiency power transfer and long service life.
2) Two stage gear train and straight forward construction offers less resistance and higher line speeds.
3) Automatic multidisc hydraulic brake design provides zero drag during power in and equal speeds in and out under no load.
4) Low noise operation under 80 dB.
5) Power-coasted finish provides superior corrosion resistance, ROHS compliant outdoors power.
6) Simple construction of free spool control allows 360 degree rotation, easy to operate
With winch you get:
– Plumbing fixture
– Heavy duty roller fairlead
– Wire rope assembly
– Solid hook
– Mounting kit
You can also buy winch with electric set (79 EUR):
– Solenoid valve (12V or 24V)
– Solenoid valve base
– Solenoid valve connection wiring
– Handheld remote control
Tιμή 1130 ευρώ
Specs
Value
1
Rated line pull 6810 kg
2
Max. oil flow 60 l/min
3
Max. oil pressure 13 Mpa
4
Gear ratio 17,3:1
5
Gear train 2-st. planetary
6
Brake Automatic, hydraulic
7
Clutch Freespooling
8
Rope 11,5 mm x 28 m.
9
Fairlead Roller
10
Dimensions 620,7 x 215 x 238,5 mm
11
Drum dimensions 88 x 220 mm
12
Mounting bolt pattern 254 x 114,3 mm / 254 x 165,1 mm
13
Weight 77,8 kgs
14
Line speed 5.5 – 9,3 m/min
