Page 1 of 1
αξονες απο j 20
Posted: Tue Jul 26, 2011 00:20
by zakjeep
Re: αξονες απο j 20
Posted: Tue Jul 26, 2011 09:19
by antonisxj
jeep dana 60 rear axle
Used in 1969-1983 Jeep J20 trucks
Ring gear diameter = 9.75"
Available ratios = 3.73, 4.10, 4.88 (1969-1973); 3.73, 4.10 (1974-1983)
Axle shaft diameter: 1969-1973 (medium truck) = 1 1/2"x35 spline semi-floating (5 on 5 1/2" lug pattern);
1969-1973 (heavy truck) and 1974-1983 = 1 5/16"x30 spline full-floating (8 on 6 1/2" lug pattern)
A Powr-Lok limited slip differential was offered till 1973; from 1974 and later a Trac-Lok limited slip differential was offered.
Re: αξονες απο j 20
Posted: Tue Jul 26, 2011 09:20
by antonisxj
jeep dana44 front axle
Used in 1967 to 1991 FSJ (J10, J20 trucks, Wagoneer, Cherokee)
Ring gear diameter = 8.75"
Available ratios = 2.72 - 5.89
Width: Varying widths from 58" - 62"
Note: Beginning in 1980, the differential was on the driver's side of the vehicle Closed knuckle till 1969; 1970 and later are open knuckle From 1967-1969, all 44 fronts used the 5-74x u joint inside of a closed knuckle From 1970-1973, all 44 fronts used the smaller 5-260x axle shaft u-joint (same size as a Dana 30)
Axle shaft diameter = 1 5/16"x30 spline Inner; 1 1/4"x19 spline Outer (1974-present), 1 1/8"x10 spline Outer (1967-1973) Note: 1967-1969 trucks had 1 1/4"x19 spline Inner axles
No limited slip or locking differential was offered.
Re: αξονες απο j 20
Posted: Tue Jul 26, 2011 17:11
by georgexj
Re: αξονες απο j 20
Posted: Tue Jul 26, 2011 17:15
by antonisxj
να τους πάρει και θα την βρούμε την άκρη.
(εσύ να πάς στην ΄"ανάσταση...." σου έχω κάτι εκεί.
Re: αξονες απο j 20
Posted: Thu Jul 28, 2011 17:04
by zakjeep
μετα απο ενα ταξιδακι 520χλ!!!!!εχουμε τα εξης ,οι αξονες ειναι σε πολυ καλη κατασταση εσωτερικα εχουν 3.73 βημα κ κανενα μπλοκε
!τςρα σε αυτο που μας ενδιαφερει το καρπουζι του 60αρι δειχνει αρκετα μικροτερο απο του gm 14 ,γνωριζει καποιοσ να μας πει αν οντως ισχυει κ αν θα εχουμε μεγαλυτερο υψος απο το εδαφος!!
Re: αξονες απο j 20
Posted: Fri Jul 29, 2011 14:48
by antonisxj
ο dana60 έχει μικρότερη κορώνα απο τον gm14 άρα και μικρότερο καβούκι. και αφού είναι μικρότερο καβούκι, θα καθαρίζεις μεγαλύτερο ύψος απο το έδαφος. μην φανταστείς τρελλά πράγματα, 2-3 εκατοστά διαφορά απο τον gm14.
ψάξου σε αμερικάνικα forum για το J20 και θα βρείς τα πάντα απο πληροφορίες.
