Δημοσίευσηαπό antonisxj » Τρί Ιούλ 26, 2011 09:20
jeep dana44 front axle
Used in 1967 to 1991 FSJ (J10, J20 trucks, Wagoneer, Cherokee)
Ring gear diameter = 8.75"
Available ratios = 2.72 - 5.89
Width: Varying widths from 58" - 62"
Note: Beginning in 1980, the differential was on the driver's side of the vehicle Closed knuckle till 1969; 1970 and later are open knuckle From 1967-1969, all 44 fronts used the 5-74x u joint inside of a closed knuckle From 1970-1973, all 44 fronts used the smaller 5-260x axle shaft u-joint (same size as a Dana 30)
Axle shaft diameter = 1 5/16"x30 spline Inner; 1 1/4"x19 spline Outer (1974-present), 1 1/8"x10 spline Outer (1967-1973) Note: 1967-1969 trucks had 1 1/4"x19 spline Inner axles
No limited slip or locking differential was offered.
