Why I am not worried about Japan’s nuclear reactors.
Posted: Mon Mar 14, 2011 02:40
Construction of the Fukushima nuclear power plants
The plants at Fukushima are so called Boiling Water Reactors, or BWR for short. Boiling Water Reactors are similar to a pressure cooker. The nuclear fuel heats water, the water boils and creates steam, the steam then drives turbines that create the electricity, and the steam is then cooled and condensed back to water, and the water send back to be heated by the nuclear fuel. The pressure cooker operates at about 250 °C.
The nuclear fuel is uranium oxide. Uranium oxide is a ceramic with a very high melting point of about 3000 °C. The fuel is manufactured in pellets (think little cylinders the size of Lego bricks). Those pieces are then put into a long tube made of Zircaloy with a melting point of 2200 °C, and sealed tight. The assembly is called a fuel rod. These fuel rods are then put together to form larger packages, and a number of these packages are then put into the reactor. All these packages together are referred to as “the core”.
Περισσότερα εδώ: http://morgsatlarge.wordpress.com/2011/ ... -reactors/
και στο τέλος αναφέρει:
If you want to stay informed, please forget the usual media outlets and consult the following websites:
http://www.world-nuclear-news.org/RS_Ba ... 03111.html
http://www.world-nuclear-news.org/RS_Ve ... 03111.html
http://bravenewclimate.com/2011/03/12/j ... arthquake/
http://ansnuclearcafe.org/2011/03/11/me ... -in-japan/
