Page 2 of 4
Re: Eργάτες-Σχοινιά,και σύντομα πολλά ακόμα....
Posted: Mon May 23, 2016 21:39
by quinda
Powerwinch PW12000PS is younger brother of PW12000E winch.
PW12000PS is a professional winch called ‘Performance Series’, which is setting the pace for design, durability and functionality. This is the winch destined to raise the bar for the economic winch marketplace! Created from everything we have already learned over the past 15 years, the Powerwinch brings unmatched quality and value.
PW12000 PS has two innovations:
Pull & Turn Clutch – comfortable and easy to use
New, better tie rods – higher durability of the winch construction (assembly)
Why Powerwinch?
5443 kgs of Rated Line Pull – really strong, bites almost any application
Weather Sealed 6 HP motors – rain, snow and blowing dust resistant
Heavy-Duty 3-Stage Planteary Gearbox – handles torque on demand
Heavy-Duty Drum Supports – maximum load tested all the way to stall
Weather Sealed Solenoid – one of the best on the market, waterproof
Rubber Hand-held Remote – field proven design provides comfortable use
Heavy-Duty Fairlead – brushed finish endures weather and wire rope abuse
Ergonomically Shaped Freespool Control – very easy to use – grip and effortless to operate; lift up and then turn feature insures freespool is in engaged or disengaged position, safety first!
With winch you get:
– Wire rope 9,5 x 28 m with hardened core
– Hook
– Roller fairlead
– Control box
– Cables set
– Wireless remote control
– Wire remote control
– Mounting screws set
– User manual
– Warranty card
Τιμή 410 ευρώ
Posted: Mon May 23, 2016 21:43
by quinda
Powerwinch PW12000 Extreme HD is a no compromise winch.
The advanced technology sets the new benchmark for the Extreme Series. These winches occupy the top-of-the-market, and are filled with features serious off-roaders demand: rugged construction, extreme sealing (IP68), and high performance ratings!
Why Extreme Series?
Extremely attractive design
Hardened brake, partly outside the drum
New, innovative 2-in-1 combo remote control
Great sealings – IP68 rating
Waterproof, powerful 6.6 hp motor
With winch you get:
– PW12000 Extreme HD high quality winch
– Wire rope (9,5 mm x 25 m) pre-fitted to the drum
– Heavy Duty 4-Way Roller Fairlead
– 500A HD Solenoid
– Heavy duty clevis hook with safety lock
– Indispensable large cross-section power cables
– Grip corded combo remote (wireless/wired)
– Mounting bolts
– User manual
– Warrany card
Τιμή 430 ευρώ
Posted: Mon May 23, 2016 21:46
by quinda
Powerwinch PW18000
Electric winch PowerWinch PW18000 has pulling rate at the level of 8182 kg and is one of our strongest, industrial winches, designed for hardest work. There is 12V and 24V versions and they meet the requirements of SAE J706 standards and CE .
PW18000 is a large and massive winch , designed for trucks . The true power of more than eight tonnes makes this winch unstoppable – it can handle even the toughest conditions.
While working on electric winch PW18000 we’ve been focused on quality, that’s why all of the elements are made of best materials. PW18000 can easily compete with the best devices of similar pulling rates, available on the world market, offering excellent , unprecedented price in the same time. PowerWinch PW18000 has , among others, reinforced cast iron mounting feet , economical engine with a good ratio of current consumption to power dissipation , ergonomic clutch and the best available on the market relays.
4 – stage planetary gear works quietly and steadily, reflecting the high culture of work . Unique brake placed in a drum ensures reliability and safety .
With winch you get:
– Wire rope 13 x 25 m with hardened core
– Hook
– Roller fairlead
– Control box
– Cables set
– User manual
– Warranty card
Tιμή 855 ευρώ
Posted: Mon May 23, 2016 23:35
by Φωτης ranger
χαρη ξερεις τι μου αρεσει?? :?: :?:
οτι βαζεις τιμες!!!!!!!!!
ωραιος!
γνωμη μου ειναι βαζεις τιμη βλεπει ο κοσμος και αν ενδιαφερεται περνει τηλ.
το αν θες εσυ να φτιαξεις την τιμη σε οποιον γουσταρεις ειναι αλλο θεμα
και γινεται στο μεταξυ σας. ;)
Posted: Thu May 26, 2016 13:54
by KON.GV
Χάρη εύχομαι ότι καλύτερο για το νέο ξεκίνημα!
Posted: Thu May 26, 2016 16:28
by samurai4x4
Καλες δουλειες !!
Posted: Thu May 26, 2016 16:33
by spiros.corfu
Καλες δουλειες !!!
Posted: Thu May 26, 2016 22:12
by quinda
Ειλικρινά σας ευχαριστω...!!!
Να εχουμε την υγεια μας...και ολα θα γινουν!!!
Posted: Thu Jun 02, 2016 09:29
by quinda
Oι υδραυλικοι εργατες μονο με παραγγελια ,και σιγουρα θα κανουν 1 -2 μηνες να ερθουν...
Powerwinch PW10000H – the smallest hydraulic winch in our offer!
PowerWinch hydraulic series provide pulling power from 10000 LB up to 22000 LB with single line operation. It is ideal for tow trucks, utility, industrial and trailer application. Heavy duty hydraulic motor provide powerful torque and constant line pull speed. 100% steel chassis construction and self-locking hydraulic brake is highly reliable and robust. Winch construction and self-locking hydraulic brake is highly reliable and robust. Winch construction and all components meet European safety standard and CE compliant.
The winch features:
1) Robust hydraulic motor with load control valve delivers high efficiency power transfer and long service life.
2) Two stage gear train and straight forward construction offers less resistance and higher line speeds.
3) Automatic multidisc hydraulic brake design provides zero drag during power in and equal speeds in and out under no load.
4) Low noise operation under 80 dB.
5) Power-coasted finish provides superior corrosion resistance, ROHS compliant outdoors power.
6) Simple construction of free spool control allows 360 degree rotation, easy to operate
With winch you get:
– Plumbing fixture
– Heavy duty roller fairlead
– Wire rope assembly
– Solid hook
– Mounting kit
You can also buy winch with electric set (79 EUR):
– Solenoid valve (12V or 24V)
– Solenoid valve base
– Solenoid valve connection wiring
– Handheld remote control
Τιμή 930 ευρώ
Specs
Value
1
Rated line pull 4540 kg
2
Max. oil flow 60 l/min
3
Max. oil pressure 14 Mpa
4
Gear ratio 31,3:1
5
Gear train 2-st. planetary
6
Brake Automatic, hydraulic
7
Clutch Freespooling
8
Rope 9,2 mm x 26 m.
9
Fairlead Roller
10
Dimensions 585.6 x 157.5 x 223 mm
11
Drum dimensions 63 x 223 mm
12
Mounting bolt pattern 254 x 114.3 mm
13
Weight 55 kgs
14
Line speed 4.5 – 8 m/min
Posted: Thu Jun 02, 2016 19:00
by quinda
Στα μοντέλα pw 12000 και πανω...δώρο απο εμενα κι έναν ιμάντα διμετρο,για να προστατεύουμε τα δέντρα!!!
Δεν δένουμε ποτε χωρις ιμάντα...δεν το ξεχνάμε!!!
Φιλε καλα τραβήγματα...και σ ευχαριστω!!!!
Παραλαβές και προσφορές...
Τα σχοινιά 28m X 10mm 160 ευρω!!!!!
Η γλυστρα 45 ευρω....
Το πακέτο 205 ευρω....
